I haven't had my morning coffee yet so might be a little slow but I don't understand your question. What do you mean by internally or externally amplified? Each coil discharge is controlled separately by the DME.
The coils are internally amplified. Each unit is plug and coil ( amplifier ) in one.
Can anyone tell me if coils on a 2002 3.6 Carrera are internally or externally amplified?
thanks
Marcus
If you mean are the ignition coils actually step-up "transformers" then the answer is yes.
But externally the 12 volt battery voltage is "amplified" via a DC to DC inverter to ~300 volts and that is used as the coil primary
"switched" voltage.
12 volts to ~300 volts to ~25,000 volts.
thanks
Marcus
"switched" voltage.
Thats great thanks for the info.
Marcus
