I have had this car for 2 **** days and I already broke it. I dropped a coin into the gear shift area (Tiptronic) and it got lodged in there somehow. I can shift into drive but I really have to force it obviously the coin is stuck in there. How do I take this area apart? Is it as easy as popping off this trim so I can get this coin out of here?
What a stupid design... i'm sooo pissed!!! :angry:
thanks guys in advance.
JIm
under the arm rest there are two screws. remove them.
Remove the shift knob. (look here below)
Lift the area.
Should be easy...
I allready did it.
Here's correct procedure to remove the Cayenne Automatic Shift Knob...
1. Apply park brake
2. Shift selector to drive.. Use a litte power if it is stuck.
3. Firmly pull shift knob off of shaft(do not press selector button on shift knob while doing this)
4. To re-attach knob...place a short flat head screw driver under button on shift knob to wedge it forward gently while push the knob/shaft back onto the selector rod. Push until it snaps to place.
5. test for proper function and shift back to park before releasing park brake.
Xavier
Edited by xaf1970
