I know that if my battery is dead/disconnected I can jumper the panel and open the front to access the battery.
Can I do the same for the rear lid?
I have dropped the motor, battery is disconnected, ecu is disconnected, ground wire loose on harness etc and the trunk closed on me while raising and lowering the car on the lift to drop the motor.
Is it safe to use the jumper procedure?
The front is still open, is it safe to reconnect the battery and just hit the button?
Is there a manual access that I can use? (rear bumper is off, motor is out of the car)
Thanks for the help!
When my battery goes dead. I usually open the front manually by locating & jerking the front cable runs inside of left front fender wall. Cable for ur rear lid runs right behind the left tail light. I did it a few times but only with my tail light out. If u have ur bumper removed, try to slip a code hanger then snag that cable!
