I have dropped the 3.2 from my 2001 Boxster s and found that the intake manifold, tb, crossover pipes etc are rather oily.
Does any and all oil in the intake cause suspicion of the oil separator?
Car has 85k miles, and low oil pressure/possible rod knock, but certain damage to the bottom end.
As I am tearing down the motor I will look for other possible causes, but is there a way to check if the separator is working properly with it outside of the car? I suppose ordering one from Suncoast is pretty cheap insurance for new motor, since its replacement will not be a labor issue with the motor out and torn down anyway.
Thanks for any advice.
I'd say an '01 at 85K it's definitely cheap insureance to replace. Plus you already mention the tb, intake manifold and j-tube (you called cross-over pipe) are oily. Anything more than a light misting in the j-tube alone should be suspicious. With the motor out dropping in a new one is a piece of cake. Replacing it while on the car isn't that hard, it's just more of a messy job w/ 2 awkward bolts and securing the bellows clamps.
Anyhow, take a look at the one you currently have. If it's never been replaced, it's probably a .01 or at most .02 version. Currently they are on .04 ..... which essentially means over the past 10 years of Boxster production, they try and re-design it "right" every 2.5 yrs or so ;)
Cheap insurance IMNSHO....
