I have an '04 Carrera C4s. Recently replaced battery. When I open door, there is a rapid clicking sound coming from the dash, behind the radio/heater?? So far, it stops after a few seconds or when I put key in and start car. Because it doesn't happen each time I open the door, I couldn't duplicate the problem at dealer.. Help? Thanks.
Greetings:
Check to see if you have a CD in the single CD player........remove it and try to reproduce the sound.
Chromedome
Good idea! Clicking happens when there is no cd in the player. If there is a cd inserted, the cd player will not play until it is ejected. When it is ejected, the clicking happens for a few seconds. When cd is re-inserted, the cd plays.
I'm thinking the cd player is defective.
Thanks for the help.
I have the exact problem except it's intermittent. It's definitely coming from the CD player. When it's clicking, I just eject the CD and then the clicking is gone.
- Ahsai
