To activate a relais, I need to have some small switched 12v somewhere (cayenne 2003 TT). I was thinking of using the rear sigaret lighter. Does anybody know whether this one is switched? Does anybody perhaps know which wires to take?
Any other suggestions are welcome as well.
Thanks a lot for the help.
Frank.
When I hookup my V1, I use the same power from the air suspension. Check you owner's manual, it one of the connection from the right side fuse box.
Thanks for the advice. It is a europeancar with a phone (PCM, no horn), so I will go for the air suspension fuse then.
Thanks and have a great weekend.
Frank
Drivers side fuse box 42 or 24
Frank
Thanks for the reply. Tried today for 3 hours without result (bose in the back, phone connection, sigaret lighter etc).
Is it 42 OR 24 or can both be used??
Can I just put in the wires together with the fuse or do I have to check something else?
Thanks, frank
I start to feel a bit like a ......
Tried again today, but I still have not find 12V which is only on when the ignition is on.
The fuse (24 and 42) are hot full time (ignition on or off), when I measured them today.
So again.... does anybody know where I can find 12V which is only hot with the ignition on? Perhaps a wire under the driver seat?
Or am I doing something wrong??
Frank
