Hey Loren would you happen to have a write up or an exerpt from the manual which states how and or where to set the cables for the shifter? I didn't mark them, but I did adjust them as best as I could, however I still suspect that they are not perfect- specifically the side to side cable. If you had a write up to note where to set that at it would be great, as well as one for the forward to back as well. Thanks Sean
SPR, I haven't done this mod yet so, take this with a grain of salt but, I've heard that the cables should be adjusted when the engine/transmission is hot to get the best results.
b-man
