Boxster 1997 UK 2.5L.
How do you remove the Fuel Pressure Regulator (FPR) on the 2.5 Boxster?
I tried to pull out the FPR retaining clip but it hits the air cleaner box.
Cheers,
Jules
Answer:
Just pull it as hard as you can and it will come out - there is enough 'give' in the air box, and enough 'spring' in the clip for it to force out rearwards towards the back of the car.
I guess it was installed this way during assembly since it was easier for an operative to insert in that way on a production line.
In terms of getting it back in, you wont be able to get it back the way it came out unless you use a lot of force with the risk of breaking something.
You have to put the clip back in from the engine side, with the closed end facing the engine and the open end facing the airbox.
Hope this information will be of use to someone one day..!
Jules
