Does anyone know the part # for the LEDs or where I can find the same ones ??? Also, how difficult is this to replace other than knowing how to solder ??? Thanks and have a great Thanksgiving DAY!!!!
Your profile says you have a 1998 Boxster. LEDs in the instrument cluster did not start until 2001. So, I guess you need to replace a bulb?
If, on the other hand, you have a bad LCD display, then I do not know of a replacement source.
What illuminates the center LCD isn't doing so now. Is this a bulb that needs to be replaced ?
Yes, most likely. Please do a search as cluster bulb replacement has been covered many times.
