Which is a hot wire under the seats. I have the stock seats out, and GT3's in so plenty off plugs and wires, but can't find power with my meter
Us Boxster owners are too poor to buy GT2/Turbo wiring diagrams. What is it you want to do and do you need a constant 12 volts or switched? And, why can't you use the cell phone connector since it has constant and switched 12 volts. Jeff
I'm putting in a CO2 sprayer for the intercoolers, the wiring diagram for the switches requires a 12v source that turns off when the ignition is off.
Where's the cell phone connector?
You pull off the carpeted trim panel and there will be a black unused connector with 4 wires. There is a ground, constant, and switched 12 volts. We use it for MP3s, V1s, and other things that need switched or constant power. Jeff
