New brakes - Brake Wear Light on
I checked all four corners and the sensors were pushed in all the way and all the wires looked new...as they should. I even used some electrical contact cleaner/enhancer. I was about to give up then I remembered that I had the old sensors in a box that I haven't thrown out yet. I plugged in the old sensors in each caliper and it ended being a faulty front left sensor as the light went off. :)
Thanks for all the replies.
