All,
I changed pads, rotors, and sensors on all four corners and now the brake wear light stays on all the time. Is there a way I can reset it such as disconnect the battery cable?
Car is a 2000 C4.
Thanks in advance,
Dan
Edited by F355Berlinetta
I checked all four corners and the sensors were pushed in all the way and all the wires looked new...as they should. I even used some electrical contact cleaner/enhancer. I was about to give up then I remembered that I had the old sensors in a box that I haven't thrown out yet. I plugged in the old sensors in each caliper and it ended being a faulty front left sensor as the light went off. :)
Thanks for all the replies.
