  tholyoak said:
Pin 1 goes to ground, when you move the switch, the contacts close and the different pins are now taken to ground. That is what triggers the response in the cluster. So connect your ohm meter to one of the pins on the gray cluster, the other to ground and push the switch in the direction that corresponds to the pin on the gray connector you are testing. The circuit should close, if it doesn't you have a problem with your wiring or with the switch.
-Todd
Thank you for the explanation. This weekend I'll pop off the cluster and check the wiring.
