Just got told by the shop that it's going to be brake time soon on my '99 996 with about 46,000 miles. The brake light is not on and I was curious just how soon, so...
I pulled off a front and back wheel and measured the thickness of the pads between the rotor and caliper with a vernier caliper the best I could. The front is about 5.5mm total width and the rear is about 6.7mm. According to Loren's DIY on the brake pad change, the minimum residual thickness should not be less than 2mm.
Am I doing this right, or not? How long should I wait before I have them changed? Thanks for any input.
If you change them before they wear through the sensors you will not need new sensors.
New pads are approx 12 mm front and 10.5 rear so I would personally change at 5 mm. YMMV...
