I have an 06 997s cab and am using a Racepak G2X data logger. To get RPM data, I tried linking to the OBD2 port pin number 9 (having read on rennlist and elsewhere that this is the correct pin number, although admittedly, that was for a Boxster and a 996). I cannot get RPM data. Can anyone tell me in pin 9 is the correct pin. I am using 4 and 16 for ground and power and they seem to work. Thanks
It appears that all of that communication now resides on the CAN bus - so nothing is on pin 9 of 997's.
The only signal that looks close to me is one called "Engine Speed Sensor" on C45 of the DME.
