I'm trying to see if it'd be worth it to put the GT3 adjustable swaybars on my 997 Turbo. Does anyone know what the diameter of both the front and rear sway bars for the 997 GT3?
Adding a front sway bar is real dificult on 997 design
cars. You will need to drain the radiators and remove
the hoses to get to the bolts that hold the sway bar
on. Replacing the rear sway bar is a piece of cake.
Paul
