I am shipping my 2006 997S to Europe this week and the moving company requires that the battery be disconnected once the car is in the container (steaming company requires it) The car is already with the moving company so I cannot look up the info in the manual and figured somone on this board would have the expertise to give a simple, precise overview of what to be aware of when disconnecting the battery.
Can the car be locked after the battery is disconnected? I seem to remember reading on another forum that people have had problems when their battery goes dead.
Any other issues to be aware of?
Thanks in advance for the help.
the only thing I am aware of is your power windows may need resetting so they will fit properly...or is that just the older cars?
Close the doors and open the trunk. Dis-connect
the battery. Then lock the doors with the key.
When you get the car back. Unlock the
doors and open the trunk with another
battery across the terminals in the fuse box. Then
connect the battery. Remember to connect the ground last.
Paul
Paul
Thanks Paul. Do you think there will be any issue with putting an ~ 1 inch thick piece of foam between the hood and latch and just latch the trunk down until the safety latch catches? The purpose of the foam would be keep the hood from vibrating during transit and then no battery would be needed to open the trunk at the destination.
Paul
Yeah, thats a great idea!!! I would add alot of foam on
both sides of the latch. You may also want to duct tape
the battery cables down so they don't shake all over the place.
Paul
