Hi All,
Last night while changing out my O2 sensors I found this plug tucked in with the wires for the O2 sensor on the right side of the engine compartment. The wires are bundled with the wires to the mass air flow sensor. Anyone have an idea what this plug is to? I had a new engine installed less than a year ago; could this be something for a car with other options? Notice the plug has six female receivers that are number 1 to 6. My Durametric reader didn’t pick up any error codes other than the aging O2 sensors.
I found the following numbers on the plug.
1-929582
>PA66<
AMP1-828877-1
BMW 1378121
I would check the two cable connections in the deck lid and the passenger side chassis. If you follow the cable near the deck lid fan it goes to a connector. Follow the cable to the chassis near the passenger side tail light.
