It's stuck down, so if armed with a hair drier, heat it up nice & evenly and use a length of floss to separate it from the panel. Then, use a suitable cleaner to remove the residue.
Pop
The sticky tape stuff is a pain to get off if its been on there a while - but it will come off. I used the hairdryer/dental floss method then used some of that gunk/goo cleaner to get the rest of the residue off. After that washed the car, small bit of t-cut or something similar to get the fine bits off, waxed and then done!
Maplins sell an aerosol product called 'Label remover' which seems to dissolve adhesive quite well and clear off scum. A few blasts of this left to soak in makes it very easy - even using floss will leave behind some 'tack' which you will need some of this to remove prior to attaching the new emblem.
