I've lost the "jelly-bean" shaped semi transparent plastic cover from the plastic assembly that covers the alarm LED (center-top of dash)
I have asked the dealer three times for a replacement "lens" cover and even took mine in to show them the piece that I am missing, but every time they tell me they have to order it specially for me. They post it to me and this part always turns up!
Does anybody know the correct part number for the part I am looking for please?
Chris,
Go into the dealer where you order your parts and ask to look up the part with whoever is looking at the exploded view. Sometimes these pictures are hard to to figure out.
Good Luck,
DQ
You might need to buy the sensor itself. The part they have provided you is the cover/surround rose (not shown below).
Item 1 is the "mounting light" and item 2 is the "sensor." I can't tell for certain which you would need; you should consult with your dealer again.
--Brian
