Does anyone know how to wire in this part, called a "suppression cable harness", part number 000 043 204 30, pictured here:
I had read that there was a TSB on this, to correct AM radio static caused by interference and the brake sensors, but I have been unable to find this topic on the TSB's.
The silver connector looks like it plugs into some receptacle in the back of the radio, but I'm not familiar with this. Since both wires that come out of the suppressor are gray with a pink stripe, I am assuming that it gets connected in line, but where?
Car is 1997 Boxster with a CD-210 radio and I get loads of static, even though I have done the A-pillar ground connection fix (made it a little better, but did not "cure" it).
Regards, Maurice.
