Hi everyone this is my first post and unfortunately its a posting about a bit of a problem I'm having.
I recently purchased a 2006 Cayman S with has PCM 2.1, PASM, TPMS, and Sport Chrono Package Plus as options.
I'm trying to turn the daytime running lights on but when I go into the Main Menu and press set, there are only two choices available to me, Main Display or PCM. There is no choice for Individ. Memory which is where the setting for the DRL is supposed to be.
Am I missing something or doing something wrong... OR is there something wrong with my PCM system. I thought Individ. memory came with the Sport Chrono Plus option w/ PCM.
Any help would be greatly appreciated.
Charles
Charles
You aren't doing anything wrong, the Individual Memory should be on the same screen as the Main and PCM options but I do remember that you have to have a key in the ignition and the ignition has to be on for the option to be there, try that first.
If not then check that your car does indeed have Sports Chrono Plus, option 640 (Check the options sticker) if it does then perhaps it is a PCM coding issue.
Edited by Nick_USA
