Hi
I am looking for a set of track day wheels for my 2005 Boxster S. I have checked the TSBs but I am still a little confused about this!
The car presently has Porsche Carrera Techno 19" wheels on it at the moment. They are:
Front: J8 x 19 ET57
Rear: J9.5 x 19 ET46
they look like this:
I have found some Porsche Turbo II alloy wheels on eBay with the following offsets:
Fronts are 8.5" X 18" with an ET52 offset
Rears are 10" X 18" with an ET47 offset
They look like this:
They are a bit wider and the rear offset seems to only be 1mm different - which I doubt will make much difference.
Am I right in thinking I will need a 5mm spacer for the fronts?
The TSB shows that a 19" wheel will fit with these widths.
Please can someone help me?
Scrawf
Edited by Scrawf
Front: J8 x 19 ET57
Don't know about fitment. The front one are going to extend outside 11mm more than the original. You can check wheel sizes/offset and their effect at http://www.1010tires.com/WheelOffsetCalculator.asp
