Hi, my 99 5spd gearbox seems fin and solid as does the clutch (pretty low miles), 2nd gear grinds up and down & requires DBL clutching always. 3rd grinds to a much less extent. First I don’t care about.
Everything else is fine, no howling and the like. Pretty darn low milage. Is it possible to remedy this without a complete rebuild?
Can it be done by just removing the gearbox (instead of complete transaxle)?
DIY (pretty experienced amateur, lots of motors…complete renovations)???
Any guess on the cost from good indie?
Thanks, PK
P.S. Any peephole to see the wear opn the clutch
