Ok, this is a repost from the Rennlist Forum
Well I had a new Fuel Pump installed in my car, and I still have a loud whining noise from somewhere in the front of the car..
So as I continued to poke around the car, I noticed when i released the fuel filler cap the whining noise would disappear.. when I would tighten the cap back on the noise would gradually build up again ..
The noise is like a cat meowing intermittently..and occasionally it wines for longer .. but like i said when i release the fuel cap the noise goes..
I'm totally stumped .. anyone have any ideas ??
Its driving me crazy :cursing:
On some of the early 996's there were problems with hose ties near the fuel filler. This could cause a variety of problems from fuel filling problems to a buzzing noise at the filler.
On US/Canada cars there is a fuel return that also returns vapors to the fuel tank - on some of those cars there is a valve that can fail that will cause a similar buzzing sound.
Those are the areas I would look at first...
Ok I removed the guard liner and theres a black box in there with lines connected to the fuel tank, I'm assuming these are return vapour lines?
This seems to be where the noise is coming from , there's a valve coming out of one of the lines. should I replace this valve?
I'll take photos if this will make it easier
Really appreciate your help on this Loren. Thx
