I have a 2003 C2 cab. that is going out of warranty on 11/30. I only have 11K mi. on the clock. What are the common issues that I should have my car checked for before my warranty expires? I had my car in the shop this week and the tech discovered a slight leak in the RMS, which was replaced under warranty.
Is there anything else I should have my car checked for? Should I consider a extended warranty? I plan on keeping my car.
Many thanks!
Mike
Mike,
Guess you have to have faith in your tech to do a proper overall inspection. Do you have a good indie in your area that would give you an objective look at your car? The dealer in my town are such jerks I wouldn't trust them to tell me anything.
After your warranty expires you should be able to get another one very easily because of the low miles on your car. There are some good threads on this site for reputable warranty companies. Hope this helps.
Good luck! <_< :cheers:
Phillip
Many thanks!
Mike
Mike,
Just another bit of info...You should be able to get another warranty that covers you for another 4 or 5 years (or even longer) for about $2100. Well worth it in my opinion (considering a water pump will set you back about $850.)
Just a thought..
Phillipj
Many thanks!
Mike
Mike,
Just a thought..
Phillipj
Thanks Phillip,
Do you have any recommendations on where to purchase a extended warranty?
Mike
Be real careful on those 3rd party policies. Really read the fine print. You may find yourself paying high out of poclket for repairs. I am not so much an advocate of these policies. First off even if you only have a water pump changed out, it's still only $850 compared to $2100. By buying one you are betting the farm that you will need it. Based on the feedback on the C2's it seems these cars are petty reliable. These companies know it and make huge $$ off of these policies.
If you do decide to get one, make sure the shop that is doing any work does not tear anything down until the inspector shows up and vlidates the failure ( which could take days). If you don't you may find yourself paying for the whole job anyway.
BTW - most don't cover emissions and for the most part O2 sensors and other sensors is usuually the weakest link.
If you have the official extended warranty booklet, read it very very carefully as items you'd think should be covered are not. For example, no part of the PCM system is covered and whereas the window motor is covered, the regulator that's bolted to it is not.
Also, rattles and squeeks are no longer part of the extended cover so if there is an issue, get it looked into now and make sure there is a history to it if you need to follow it up post-expiry.
Regards
Pop
