Hi all,
Recently the water pump gave up and caused coolant leaking, also broke the drive belt. Going to replace the water pump and belt, is there anything else I should do while I'm at it? like thermostat? is it necessary or just an option? someone mentioned to me to check the belt tensioner/idler pulleys, should I change those too? Thanks! :) :D
Here it is on a 996. http://p-car.com/996/diy/waterpump/
Belt replacement on a 986. http://www.renntech.org/forums/index.php?s...amp;#entry10610
Check the bearings on all pulleys.
Don't know anyone that routinely replaces the thermostat when the pump is replaced.
Have seen this aftermarket pump on ebay.
http://cgi.ebay.com/ebaymotors/New-Porsche...sspagenameZWDVW
Takes pictures and notes and then put it in the DIYer section.
