I don't know the proper name for these so it's about impossible to do a search.
Anyway.......mine dont line up very well and I'd like to adjust them, if I knew how. I see some hard rubber on the inside of them but dont want to just start pulling. Bentley doesn't help on this.
Also my clamshell cover could use some slight adjustment, if anyone has words of advice I'd appreciate them.
When the top is down the clamshell is just slightly higher in the center rear then when there is no roof under it. The leading edges need a slight tweak here and there.
I am not sure if those adjust but they do pop off. They are where the Roof Transport System mounts go. You could just try pushing them or pop them off and see if you can adjust them. If you need more info on popping them off look at the Boxster Wiki site. :D
Edited by rick3000
