Hi guys need your help again i noticed this morning that my c2 is dripping oil i think its coming from the oil pan on the sides do i need to re seal it with tri-bond or loctite? any help will do thnx in advance :)
A leaking oil pan is pretty unusual - unless it has been hit and cracked.
I would clean all the oil off - drive few miles and then look again to see where it is coming from.
Check your RMS?
Check your RMS?
Rear main seal? my oilpan is leaking on the sides where some kind of red gum or sealant
how do i knw if its the rear main seal?
