:unsure: I have a lowered 996 C2 Cabriolet with a Bilistein PSS 9 suspension. I destroyed a perfectly good set of tires within 2,500 miles. Does anyone have any suggestions on which direction I should go in to correct this issue. Many of the sites I visit have adjustable rear lower arms and adjustable rear links.
Did you get the car aligned after lowering it? After alignment was it within spec?
Yes I did, but I am sure that they were not able to get close to spec due to the limited adjustment of the factory suspension.
I think camber plates may be what you want. Sorry I can't be any more help.
Edited by Stefan
Thanks, I am still waiting to see if anyone used these adjustable rear links or used something different.
