what is the other components of the ceramic brakes other than the rotor and the calipers...any other parts?
cause the local yard just got a smashed up 07 turbo with ceramic brakes....thought i pick em up...
Lemon
Make sure you get all the caliper and rotor parts including the bolts that hold them on. On the rear brakes you will also need the inner splash shield.
If your 997TT is a MY08 then you will also need to take the short brake line from the flexible hose to the caliper for each wheel.
now the idiot junk man wants 6.5k for them...it was 3k two days ago
Lemon
Lemon, he's not such an idiot, he just knows how much they are worth. Sorry you did not get them for $3K. Though, $6.5K is still less than $8.2K.
