I have an 01 turbo with the stock moveable wing and need to buy a tap for the thread inserts that attach to the hydrolic rams. I know you need a 14mm allen socket to remove these but I need the dimensions of the bore and thread pitch as I am machining an extension piece to raise up 1 inch for an aftermarket spoiler. I know it is close to 21 or 22 mm but because I have to order this tap I need to know for sure. Loren can you perform another miracle?? thanks Mike
You likely need to take one to a machine shop where they can measure it.
Porsche doesn't document (to the outside world) specs on how the parts are made.
