I am working on the exhaust system and there is a type of sensor, I think, that is attached to one of the heat exchangers. I cannot identify this part and don't know how to go about to repair/replace it. As you can see the part is partly broken off the hear exchanger.
Can someone help me with advice on how to go about fixing this? I will need to take the complete exhaust system off anyways. Are there any other parts I should be looking at replacing. Help appreciated.
OK. So seems to be the EGR valve? How is this mounted to the heat changer? It is not clear from any parts diagram I am looking at how it is mounted. Is there some good diagram available somewhere?
