This question is for Loren or who else might be able to help.
Working on the rear of the car now and wondering about getting the axel out of the wheel carrier.
I understand that it is possible to change the wheel bearing without disconnecting the axel off the transaxel. By taking out the bolt on the lower control arm and swinging the carrier out of the way. First dissconnecting the sway bar and track rod. I suppose some confusion might come of people calling the parts different things. Anyway is this the way that it should be done? Or is there a better way?
My parts diagram lists the names as the following....
1) Wheel Carrier
2) Bearing
8) 8 Control Arm
9) Lower Control Arm
17) Track Rod
Edited by seafeye
