Help!
2000 Boxster S 70000 miles with CEL on
OBD II found the following codes: P0139 and P0140
It said the Oxygen sensor on Bank I Sensor 2 is not working.
Questions: Where is it located? What should I do?
1500 miles ago I changed oxygen sensor on passenger side before the CAT with new OEM part.
Jacky
P0139 Ageing of Oxygen Sensor After TWC, Bank 1
P0140 Oxygen Sensor After TWC, Bank 1 – Open Circuit
P0139
Potential causes:
Implausible signal from oxygen sensor
– Oxygen sensor
P0140
Potential causes:
Open circuit in signal wire or ground wire of oxygen sensor.
Oxygen sensor heating not functioning.
– Wiring harness
– Oxygen sensor
– DME control module
Without seeing your O2 sensor voltages (before and after) it would appear that you have a wiring/connector problem at the sensor(s).
If the wiring looks and tests ok - then I would replace the O2 sensor before the cat first - clear the codes and see if the after cat O2 sensor r a code again.
P0139
Potential causes:
– Oxygen sensor
P0140
Potential causes:
– Wiring harness
– Oxygen sensor
Hi Loren,
Oxygen sensor on the passenger side before the CAT was just replaced with NEW one oem 1,500 miles ago (2 months ago). Wiring looks ok. Is it time to buy new one for after the CAT on the passenger side?
I hope you are going to do this yourself.
Some sources for cheap parts and a DIY with pictures here
It is really trivial. Or at worst, have a muffler shop do it with the part you bought online. Don't pay the dealer just to replace the sensor. Only pay them if the swap doesn't cure the problem and you need further diagnosis.
