Since I could not find any documentation on the Mass Airflow Sensor on my 1984 Carrera and I was curious to see how it looks inside I opened it up to see how it looks. Is there any detailed information available on this part? One screw had a red dot on it so I assume there is some issue with opening it up. Can you just screw it back on or is there anything special with it once you take it apart?
Why in the world would you take it apart?? I think you might have damaged it beyond repair. Try putting it back together and see if it still works. Best of luck.
