Had to unhook my battery and now the radio doesn’t work. When powered it on, the word CODE appeared, did not flash. I think I may have incorrectly entered code, then CODE went away and display is blank with only a back lighting. I tried to leave the radio on for 24 hours, but problem remains. I have successfully put code in several times in the past with no problems.
The radio is a CR1 in a 1994 928 GTS. Any help would be greatly appreciated.
i am having the same problem w/ my 2000 c4s 996. only this time when i disconnected the battery, it didn't ask for the code. don't know what to tell you, just that sometimes misery loves company.
typhon
