Hi 996 buddies:
May I pose a question for those that want to help a fellow 996 TT enthusiast
I will be replacing the clutch on the car next week and wonder if the Rms issue also affects
996 TT. Should I also replace the rms seal although it is not leaking anything right now?
Thank you all you help is much appreciated
The turbo uses a different engine case compared to the 986/996 and to my knowledge isn't effected by the RMS problems..... if it isn't broke, don't fix it!
Hi 996 buddies:
It would be very rare to have a leaking RMS on a TT engine. The TT engine is a derivative of the 993/964 engine - not the M96 Boxster/Carrera engine.
