Hello all,
I have a 2000 C2 Cab and the top will only work using the key. The brake light works when the emergency handle is pulled, spoiler and hoods are all latched. When I push the dash switch, nothing happens. No blinking lights, noises or anything. Maybe its just the dash switch? I've searched the archives and this doesn't seem to appear anywhere. Thanks in advance for any help.
drjackryan
Could be the switch from your description. You can remove it and cross the wires to close the circuit. Switch would be about $35.
