Ok, so what keeps a double din unit from falling out after you put it in the place of the oem radio and move the ac control unit to the cd holder area which is then removed? :)
It depends how you install it, you can still use the original radio brackets if you bolt them on to the sides of the new radio. It's a very easy mod to secure it properly. The harder part is fabricating a piece to cover the gap that you will get once you relocate the ac control unit because the hole becomes a little larger than the standard double din by about 1/4" or so.
