Looked (search terms +clutch+replacement) and was unable to find any results... Are there any DIY instructions for replacing the clutch/flywheel?
Essentially the DIY consists of:
1. Remove transmission
2. remove & replace the pressure plate and clutch plate which is attached to the flywheel.
3. remove & replace the throwout bearing in the transmission bell housing.
4. replace transmission.
done. Total time 4 hours.
let me know if you have any questions.
  • 4 years later...
I just finished the clutch in my car 3 days ago, and it was quite similar to the boxster post.
Edited by nbeihl
The biggest tip on a clutch replacement is to R&R the clutch slave and upper bell housing bolts after you have tipped the trans down. It gives you much easier access.
The clutch is one of those "while you are in there" jobs, do the AOS and IMS bearing too.
