Are you sure your fan is bad?
There have been a number of reports here where folks found weather stripping or something else hitting the fan.
Do a search here to find more...
  bbooth said:
I need to replace the AC/heater fan. I am buying a new fan from AutoHaus Arizona. Any advice?
I bought a new fan and it also doesn't work.
I have seen several posts in connection to problems with the ignition lock and am wondering if this could be something related to that.
I had a new ignition lock replaced a month or two ago.
Thoughts?
