I am installing a new Nav system tomorrow, and I need to connect the Reverse signal and Parking brake switch to the unit for safety reason.
Where is the best easiest place to tap into those connections?
I never connect these.
If you have a DVD system you or the passengers will only be able to watch movies when the handbrake is off.
