Well,
My 99 996C4 is still losing coolant, seems to be using around 2 litres over 6000 miles. The dealer has done 2 pressure tests and the vacuum one and nothing shows up. He now added a die to the coolant which may show a leak with a black lite. Current suspect is a hairline crack on the coolant tank which only leaks during vibration, it's bizarre but nothing is showing up on the sucker. The dealer has been excellent so far and done all the tests at no charge.
Hopefully, the dye will show something up after a week or so.
