I think I'm down to the last leak in MY99 Cab (for now!). Thanks to the folks that helped so far. :cheers:
This one is at the bottom of the drivers door (RHD) under the speaker BUT NOT due the the liner as this has been changed and checked - I am convinced of this!
The fabric part of the interior door trim seems to be 'sucking up' the water which collects just under it.
The pool of water stays inside the groove/seal on the body of the car - it is not a huge amount. It is not going in to the cabin (which is a plus), but when I open the door after rain I notice the fabric under the speaker is wet and sometimes it drips on the floor.
My hunch is that it's coming through the gap between the door and the front wing and there should be a seal which diverts it out but it's not doing it's job efficiently! Any ideas? Thanks in advance.
