I've got an annoying rattle that i've traced to the drivers side belts cartridge/drum in the rear panel. Theres a wire connected to it which i assume is for firing the pretensioners, does anybody know if theres any specific instructions for following before removing it or is it just a case of disconecting the battery first? Has anybody else had this or a similair problem? thanks sc :)
Model and model year?
Us/Canada car or RoW?
oops sorry, uk c16, 996 tt 03 which i'm led to believe is the same for all models from 02 on bar targa and cabrio?
As of MY02 all 911 models are fitted with belt tensioners and belt-force tensioners. The pyrotechnic ball belt tensioner is combined with the belt-force limiter in one unit.
Yes, disconnect the battery and remove the key from the ignition. Wait at least 5 minutes before proceeding.
The electrical connection (fuse/trigger) to the seat belt reel will likely need a screwdriver to remove it.
If the belt fires the tensioner then it will have to be replaced.
