With the install of the PSS9's, is it necessary to also install new sway bars and drop links? I've done a search and some imply it must be done, others make no mention about doing anything more than installing the PSS9's. If its optional, what are the pros and cons to adding them?
I've got a 2002 C2 Cab.
You may have heard this already but I installed the PSS9's and the car drove well. I did upgrade the sway bars to the Weltmeister fully adjustable set to improve the turn-in. The sway bar iimprovement will reduce understeer at the expense of ride quality. Unless you are doing track events or Autocrosses you won't need stiffer sway bars.
