From review all the prior posts I am asking Loren for help.
I just purchased 2002 Boxster. I need my radio code. I called a local dealer and gave them the info below including vin# and my ID. They provied me with a code (4321) it does not work and they said I would have to bring the car into the dealership.
The radio info is as follows
Becker 1
Model 4462
Serial-15000604
(I obtained the serial number by reading your prior instructions to other members to hold the TP button for ten seconds, then rotating the tune knob)
Thanks in advance for the help
The code is usually (but not always) within 2 digits of the decoder. Try 4323, 4322, 4320 and 4319. You get locked out after 3 tries, and have to wait a while before you can try again.
