Hi All,
Planning to help my buddy change the air filter on his 2k Boxster S this weekend. Is there a DIY for changing the air filter somewhere? I tried searching, but no luck. Dealer was asking $800 for a 30k service. Thanks again!
No DIY because it is so simple :)
The hardest part is getting at the engine. If your filter is particularly dirty, some loose dirt may fall into the clean side of the intake when you remove it. This is not a problem, just make sure you vacuum it up and/or clean it out with a damp cloth before you install the new filter.
Good Luck,
Graeme
