My turn signal is out on my 95 993 ( the rear left). Is the turn signal and the small outer bulb on a different fuse? The break light is working, just not the turn signal lights.
Thanks Chris
The outer bulb is the side marker light and it should come on with the headlights.
Have you tried the emergency flashers to see what comes on?
If none of the lights flash then I would suspect the flasher relay.
Thanks for the advice on the hazards. My right one flashes just not the left. Also with the headlights on the side market lights work on both sides. I have changed the bulb for the left flasher but it is still not flashing. I suspect it is getting power but the housing around the bulb is defective. This housing comes off (not sure how) as it has wired clamps. What are your thoughts?
